11-08-2016
08:28 AM
- last edited on
03-06-2024
01:32 AM
by
ROGBot
11-08-2016 09:36 AM
11-08-2016 10:44 AM
FonzieBulldog wrote:
I suggest that you download the proper drivers from GeForce web page.The fan and heat problem is another issue.Check through the task manager if there is any software who is making your computers life harder than usual when it runs.The second who i dont recommend if you dont have the proper experience is to open it up and change the CPU cooling paste.My choice will be the Arctic Silver CPU heat paste.But when i read that it is only three months old i suggest that you contact the place there you bought the computer and use your warranty.Hope you will solve it out when the Asus ROG GR6 is a nice little computer. 🙂
11-08-2016 12:03 PM
11-08-2016 12:10 PM
11-08-2016 02:02 PM
