Problem with pc
Dapi
I just built a PC, but when I turn it on (I don't have Windows installed yet) I don't get into the bios and ami, but I get stuck at something (in the photo). I loaded 2 mice, both wired and usb, I tried all the USB ports (about 10-12 in total).  The cursor doesn't even appear on the screen. The same problem when I insert the keyboard. However, their lights come on, a sign that they are receiving power.
But these peripherals work because I tested them on the laptop. I updated the bios and it still doesn't work.
The whole set up is Rog btw:            ASUS ROG STRIX B850-E GAMING WIFI motherboard, AMD Ryzen 7 9800 X3D, ASUS ROG Hyperion GR701, Asus PRIME OC GeForce RTX 5080, G.Skill Trident Z5 Neo RGB, DDR5-6000 CL30 32GB, Samsung 990 Pro 2TB SSD, Asus ROG Strix Black 850W, Asus ROG Strix XG27AQDMG, Asus ROG Gladius III AimPoint, Asus ROG Strix Scope II 96
Silent_Scone
Super Moderator
Hi @Dapi
I can't see any photo? Need to determine where you're getting stuck.
I uploaded it.
