GR6 connecting 5.1 audio system - solved
4r8en
Hello everyone,
I'm new to ASUS so please forgive me my ignorance 🙂
I have an Asus GR6 desktop and I want to connect my Logitech X530 5.1 audio system to it.
The problem is that I'm able to get sound only from front speakers (center port in the rear) as both center and rear speakers stay silent.
After some digging I found out that I can't repurpose first and second jack on the back to serve as center and rear respectively, they stay as line in and mic in even after changing it to center and rear speakers. My Realtek audio driver is 6.0.1.7960 with supremefx add-on (skin?), I've tried the newer one but it doesn't show in taskbar.
Is there any other way to repurpose rear audio ports? In my previous PC with Gigabyte mb it was done by simply changing it in ports settings (also Realtek).
Thank You
toronto699
Try This Driver From My G30AB , It Has Speaker Fill Option , Make Restore point , if you want to go back to your original , Driver W 8.1 audio driver Version 6.0.1.7035
2013/09/27 Works In W10 I Use This Driver On Two Other PCs , And Have 5.1 audio ,
https://www.asus.com/us/supportonly/G30AB/HelpDesk_Download/
Thank You, this actually worked. Thank You once again.
toronto699
4r8en , Welcome Any Time ,
