G35DX - problem with myasus application
MFrost
When i was updating windows myasus application stopped working properly. The icons on the left side of the myasus app do not work. eg I can't check if there are any driver updates available. How to repair this problem?
7 REPLIES 7
toronto699
toronto699
toronto699 wrote:
Driver Page
https://rog.asus.com/us/desktops/full-tower/rog-strix-ga35-series/helpdesk_download
Really? Do you think I haven't looked there? It does not work....these drivers
toronto699
Yes Really
rs3_quattro_8v
Same thing happened to my G35DX and MyAsus app recently. I just uninstalled it, wasn't terribly useful and didn't offer any drivers or updates that were not on the web support page.
MFrost
I also had problems with usb. When I connect 5 hdd drives, some hdd are not properly mounted to the system. The problem was started after updating to windows 10 20h2. This is probably a problem with the motherboard drivers. There are no new drivers on the asus website. There is no support.
Unfortunately, the computer is not polished. I put it back in the store. I don't have time to solve puzzles. Support doesn't know either. I'm embarrassed.
Blake1
Dear both,
There has been a new update for ASUS System Control Interface V2 driver, V2.2.37.0.
May you help to update it and reinstall MyASUS APP?
