01-19-2025 02:36 PM
My phone, which supports 120 fps in the game settings, displays only 91 and no higher in the mache. Once I rebooted the device, I saw 120 fps after rebooting. After that, no matter how many times I rebooted the phone, fps did not rise above 91!!! please help
01-19-2025 11:24 PM
Try to adjust graphic settings? or re-install PUBGM
Mine runs at 120. no problem..
01-20-2025 11:00 AM
I did everything
rebooted the device
deleted pubg
downloaded pubg
reset the device
nothing helps!
01-19-2025 11:54 PM
Lag/Performance Issues:
Touchscreen Problems:
Overheating:
Battery Drain:
Audio Issues:
Network Issues:
01-20-2025 10:56 AM
You, without understanding my problem, write me some advice that will help me in no way and will not solve my problem, because I bought a NEW ROG PHONE 7 16/512 and you write to me about problems with sound, I sent a screenshot of the latest update to my phone and you write to me about the update, what’s wrong with you dude?
01-20-2025 08:13 PM
Hi i also have the same problem but different device and game, I just bought a brand new ROG Phone 8 and it does not support 120fps in BR Mode in Garena Call of Duty Mobile but in the game settings i can max it out in 120fps but in game genie, it's only limited to 90fps, I already did everything but i can't find any solutions
01-21-2025 09:02 PM
Your device firmware is not up to date.
The latest version available is WW_34.1010.0820.90.
Please refer to the link below for update details:
🔗 Firmware Update Notice
