12-08-2023 07:14 AM - edited 12-21-2023 07:00 AM
While gaming and doing more CPU-intensive tasks there is always a chance of the phone getting warm, to fight this we have created the AeroActive Cooler 7, the perfect companion for your ROG Phone, allowing your CPU to stay cool to avoid lag and even giving you better performance while at it.
The AeroActive Cooler 7 is a thermoelectric fan exclusive to the ROG Phone 7 that works together with a Peltier element to achieve lower temperatures than a normal fan could reach.
With the AeroActive Cooler 7 connected, you can go to Armoury Crate > AeroActive Cooler 7 > “More settings” and there you will have 4 different modes to choose from:
These modes also appear if you open Game Genie in-game and select “Cooling mode”, giving you the same 4 choices.
But while keeping your ROG Phone cool is a great thing, more performance is even cooler. You can access X-Mode+ when the AeroActive Cooler is connected, allowing for the highest performance your ROG Phone can reach, this can be activated either on Armoury Crate or Game Genie.
The AeroActive Cooler conveniently has 4 mappable physical buttons which are ergonomically designed to give you a controller-like experience when holding your ROG Phone, to customize these buttons you can go into Game Genie inside of your game > AirTriggers > “Cooler buttons”, here you can easily drag and drop the buttons to your desired position to map them to any on-screen function for that specific game.
If you are connecting it to a ROG Phone 7 Ultimate then you will be able to use the AeroActive Portal, which is a little black “door” on the backside of your ROG Phone 7 Ultimate, this door will open automatically when you connect your AeroActive Cooler 7 for optimal airflow and the best cooling your phone can get.
The AeroActive Cooler is more than just a cooler for your ROG Phone. It also has a 3.5mm headphone jack for low-latency audio and easy access, Aura RGB to customize your cooler for different occasions, a kickstand to watch your phone at a comfortable angle, and the Cooler even works as a subwoofer, providing you with a 2.1-channel sound and giving you an immersive experience like no other.
02-13-2025 05:01 AM
Hiiii Mattias, thanks to your tutorial!! In your text, you just said "X mode +", what do you mean about "+" (plus)??? Is that a different config of those that are using the aeroactive?? The true is that before I bough my ROG 6 + Aeroactive 6, I used to watch Youtubers review the phone. I so, I was expecting that the X-mode (or better performance) was activated only with Aeroactive on Freezing mode. But even without the aeroactive, my ROG phone activates the X-mode...
I have another comments about the Aeroactive, but I will let it to another Discussion.
Best regards!!!
02-25-2025 05:44 AM
Hello @Adokley
Thanks for your question!
Yes, the X Mode + is a feature exclusive to when you have the Cooler connected to a power outlet this is to maximize cooling while unlocking all the performance the chip can give, since the cooler might need some extra power in the Frozen and Frosty mode, and the processor might get pretty toasty.
You can activate the X Mode + in Armoury Crate after connecting the cooler to the charger.
