Water Block with 9 pins for R6E
StefanI
I search a water block witch use the 9pin wb_sensor on the R6E.
68485
4 REPLIES 4
JustinThyme
I dont think anyone has made one yet but seeing how the first and last one to be made was by Bitspower for the M9E Id bet they have one before long.
The stage is also set for others if they want to pursue it.
Come Christmas I'm looking to add the Monoblock from EKWB.
EK-FB ASUS ROG R6E RGB Monoblock - Nickel:
https://www.ekwb.com/shop/ek-fb-asus-rog-r6e-monoblock-nickel
There will be no Rampage VI extreme blocks that will use that connector,first of all, because of the price,block with all sensors cost around 300$,second,CPU market spews now approx 2 gen of CPUs a year,so there is no financial benefit for companies like Bitspower to make that kind of blocks.Now that's just useless connector on motherboard,which could have been better replaced with high AMP fan header or RGB header,or they could have used free space to make another 8 pin EPS insted of 4 pin.Poor design choices from Asus unfortunately.In my opinion,I think Asus soon will trow rev2.0 of this motherboard because of all of the faults(like first PCIe x16 slot that's in most cases unusable,no m.2 heatsinks,only one m.2 connector on mobo,poor motherboard protection in the box,lack of USB 2.0 internal headers,small number of fan headers poorly distributed on motherboard,insufficient power delivery and so on and on )
