Say goodbye for Intel Turbo Boost MAX 3.0 Driver due EOL with SA-00243
restsugavan
Level 12
A potential security vulnerability in the Intel® Turbo Boost Max Technology 3.0 driver may allow escalation of privilege.
Intel is not releasing updates to mitigate this potential vulnerability and has issued a Product Discontinuation notice
for the Intel® Turbo Boost Max Technology 3.0 driver. :cool:
Intel has issued a Product Discontinuation notice for the Intel® Turbo Boost Max Technology 3.0 driver and
recommends that users of the Intel® Turbo Boost Max Technology 3.0 driver uninstall it or discontinue use
at their earliest convenience. This does not affect Intel® Turbo Boost Max Technology 3.0 functionality when
used with in operating systems with native support (Windows 10 RS5 and later).
https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00243.html
Microsoft Windows 11 Insider Preview Build 25375.1ZN Intel Core i9 7980XE 2.6 GHz 020006F05 Microcode ASUS RAMPAGE VI EXTREME MODDED BIOS 3701 SAMSUNG ODESSEY G9 FIRMWARE 1017.0 NVIDIA RTX 4090 24GB GDDR6X 256GB GSKILL DDR4 16-18-18-36 3200MHz SAMSUNG EVO 970 PLUS 1 TB x 3 HARMAN JBL 9.1 Sound Bar DOLBY ATMOS 9.1 :cool::cool::cool:
9 REPLIES 9
H-de
I always used native TB3 😛
not sure why ASUS have OS Support as Default setting for TB3
Other mainboard manufacturers like GIGABYTE have TB3 native as Default
ThrashZone
Bloat/ crapware always disable anyway and kill it in task manager so it never starts again and a little cmd magic
Good riddance !!!
Jpmboy
remove INtel Turbo Boost 3.0...
Here's a proper way to disable the application (with device driver intact).
1. RIght-click on the tray icon, and disable it.
2. Open Task Scheduler and disable Intel Turbo Boost Max Technology 3.0
3. Open Command Prompt and type “sc config ITBMService start= disabled”
4. Reboot.
Now back into bios and disable EIST (Enhanced Intel SpeedStep), and Enable SpeedSHIFT.
F10 to save and reboot.
[SIGPIC][/SIGPIC]
ThrashZone wrote:
Good riddance !!!
Jpmboy
Thank you ThrashZone 😮
Start CMD as admin and enter
C:\Windows\system32>sc delete ITBMService
EaglePC
guess this explains it to my post https://rog.asus.com/forum/showthread.php?116747-Windows-10Turbo-Boost-3-0-eliminated#post798848
Asus Rampage VI Extreme / Intel I9-7940X / Corsair H115i Pro / CORSAIR Vengeance RGB Pro 32GB (4 x 8GB) 3000MHz / EVGA GeForce GTX 1080 Ti FTW3 ELITE GAMING BLACK Edition / 2x Samsung 970 Pro NMVe 1GB / 4x Samsung 850 PRO - 2TB / Asus ROG Swift PG348Q / Corsair AX 1500i / Thermaltake View 71 RGB PC Case /Win 10 PRO x64
BigJohnny
Funny how they made a huge PITA to get rid of for the longest time.
Uninstall and it would come right back. Now its as simple as an uninstall.
GTi-6
This thing keeps getting installed every time I restart. But at least it is disabled now. Any idea to how to get rid of this thing completely?
I did every step above.
restsugavan
Level 12
Depending on your Windows 10 version. If you use version 2004 and above it was disable by default.
Older version must be uninstalling by manual.*
kkn
Level 14
even after a fresh instal, windows instals the intel turbo program.
there is no way to uninstal it unless you go in to registry and do some magic there or other places ( did a google on it but i did not dare to do enny thing ).
and now when i try to add a new asmsung 870 qvs drive i cant get it to format ( due to the intel turbo efing things up on me )
