01-07-2018 04:06 AM
01-07-2018 01:03 PM
01-07-2018 03:39 PM
Bash4Sure wrote:
Hah! Glad that someone brings this up! I noticed the same behavior. I was freaking out about it, too. I even changed from an EVGA X299 board to an APEX because I thought the EVGA board was the cause. Nope same situation the write speeds seem to be stuck. You will notice it can mainly be affect by Mesh frequency.
One thing we have in common is the 7920X.
Either the smallest of the HCC die chips has been somewhat cut down on the memory controller by intel hence there is not a single review unit send out by intel so there are literally no reviews on the 7920X out there so no one notices it's shortcomings OR Aida64 just doesn't monitor the write speed correctly on this chip. Because what leads me to this conclusion is that I tried other benchmarks and they actually report a write speed that is somewhat higher than read and copy, more like it's supposed to be.
For reference this is a Corsair Dominator Torque SE 3200Mhz (I have tightened the second & third timings a lot and Mesh runs @3200, but same overall scenario):
01-07-2018 07:48 PM
01-07-2018 07:43 PM
01-07-2018 07:56 PM
Menthol wrote:
Have either of you tried one of the memory presets in the memory timing section of the bios? I don't know what presets are available for the R6E but the R6A has a 1.4v 4000mhz profile that works really well. I see some guys reporting it works for them using Gskill 3200mhz 14-14-14 kits and 3600mhz 16-16-16 kits, I am using it with 2 kits of 3600 15-15-15 at the moment, these type of bios presets is one of the reasons I like to purchase the top boards, it can help the experienced like myself. Even if you can't run at 4000mhz you can still select the profile and then set a lower speed and be in the ballpark so to speak.
What cache speed are you running?
01-08-2018 01:04 AM
gridironcpj wrote:
I have the Extreme, which turns out to be a worse board for memory overclocking (go figure). I had so many issues trying to stabilize 4000MHz with the C16 3600MHz Trident Z RGB kit I had. I was able to pass 1000% of HCI only for it to fail before 50% the next day. Again, it could be the 7920X's memory controller somehow being worse than every other Skylake-X CPU or it could be the Extreme simply not being so Extreme anymore like it was in previous generations. I had to settle for a 3800MHz memory OC with good secondary and tertiaries.
My cache is at 3100MHz. I tried 3200, but I kept getting BSODs at the Windows login screen. This was the case even at 1.2V on the cache. I only attempted it with the 3800MHz memory OC though, so maybe a lower memory OC would not produce the BSODs. The voltage increase from 3100MHz to 3200MHz must be absurd for me. I can do 3000MHz at 1.05V and 3100MHz at 1.1V.
01-08-2018 12:55 AM
01-08-2018 02:18 AM
