03-16-201812:55 PM - last edited on 03-06-202409:08 PM by ROGBot
As I was thinking to mount the optional MOS-fan I saw that the only possible connection for this fan is the CPU_Optional slot. (You need to extend the fan-cable to reach other fan-pins on the mobo) As I cant find CPU_OPT in the Q-FAN Control Center how do I adjust this fan-speed cause it turns on very high 6000rpm and is noisy as hell!
If you have individual control for your MOS fan. the best option is to get a fan extender. They are pretty cheap and some of those sleeved ones would make your build look good.
