01-06-2019 11:18 PM - last edited 3 weeks ago by ROGBot
01-08-2019 10:52 AM
RichKnecht wrote:
I guess I am the oddball here as I really like the looks of the Omega over the Extreme. IMO, it doesn't look "cheap" at all. They used black anodized aluminum for the covers and the VRMs look like what they should have been in the beginning. I'm not a huge gamer, so I don't want or need 3 GPUs. I have a feeling this will be a big step up from my X299 Strix.
01-08-2019 01:08 PM
Abaidor wrote:
Design complexity is much less, aluminium is not expensive especially these pieces and at the end of the day its just relatively flat pieces...nothing hard to manufacture. The original Rampage VIE is much harder and more expensive if you know anything about production costs. There are changes on the PCB as well and the Start/Reset button is moved down (bad and awkward) and who knows what else lies beneath.
And the VRMs should come with a Waterblock like the Maximus Formula XI that btw has mediocre VRMs with "golden handles"....
You may like it of course but its nothing like the original and no other board is for that matter...maybe we got a unicorn and that's it....
02-22-2019 12:23 PM
02-22-2019 01:51 PM
suniverse11@gmail.com wrote:
I'm happy I built with the Rampage VI Extreme. Beautiful board.
01-08-2019 09:45 PM
01-09-2019 03:26 AM
JustinThyme wrote:
The only perceived benifit I can see is the additional 8 pin block over the previous 4 pin.
JustinThyme wrote:
As for the VRM heatsink they should have made it like the older formula where its set up for liquid instead of a 10K rpm baby fan thats gonna get gunked up and die in less than a year unless you get tired of hearing the tiny fan screaming like a banshee!
JustinThyme wrote:
Big problem is reduction of PCIE slots. One cannot run 2X GPUs in SLI and 2X PCIE SSDs. I see no VROC key slot either.
JustinThyme wrote:
If I was to change up boards Id be going for the WS Sage 10G instead. Im betting this wont even come in at a lower price point. Yes covers are cheaper and most of the bling is gone
01-09-2019 03:52 AM
Silent Scone@ASUS wrote:
The power solution has been upgraded so that it can handle a sustained 500W+ load, which the original R6E board can't, even with active cooling. The VRM costs twice as much, but better deals with transients (at least 30mV less sag under fast transients).
The VRM fan curves can be controlled. By default, they don’t switch on until 60C, so they’re not constantly active. You can adjust the curve as you see fit, and if the chassis has reasonable airflow, you won’t even need them.
Have a look at the manual, which is available online.
Two cards can be used with two drives. Disclaimers are added when there are conditions. As you can see there is a disclaimer for U.2, but not M.2. There is also a VROC key slot.
The aluminium cover costs $10 more than the last iteration. To buffer that cost, decision was made to remove the AD standard, which will never be widely adopted. The AX standard seems to be the next milestone. We already have two AX routers on the market, with a third on its way. As soon as client controllers are available, we’ll implement onto future boards. It's always a game of compromise. We went with a more rugged engineering approach this time. Hence the alu cover. It helps dissipate heat from drives. Not that the last iteration was bad, it's just this is better. They will both be sold. So no harm done. If rugged engineering is not you, pick something else. There are lots to choose from.
01-10-2019 03:51 AM
02-22-2019 12:28 PM
RichKnecht wrote:
Seems like this thread has become a bashing zone for Asus. Kind of sucks for us users looking for a new board for their X299 rigs that has a capable power delivery system, capable VRM cooling, and what should be great overclocking potential. If you don't like the looks, OK I get it. You already own an Extreme, so there is no need for you to upgrade....great. If the board doesn't offer the features you want/need, buy something else. I, for one, will be buying this board and I'll probably not be alone. Just like the Intel refresh of X299, some like it and some don't. I know I will not be trading my delidded chip for a soldered chip. Same goes for this refresh. Some will make the switch, some won't.
I have a feeling the direction of this thread will change once the boards start rolling out to consumers and reviewers. Until that moment comes around, I'll just wait impatiently for these to hit the shelves.
