RGB LED and wheezing noise
Jedimaster
Dear all
Since yesterday my rig is working and I connected my Phatenks Enthoo Luxe to the mainboard RGB connector and also 2 RGB LED strips on the second connector (adressable RGB is free).
But what is really anoying is the wheezing noise from the mainboard. When I switch RGB off with AURA app, the wheezing is gone??? *
Anybody with similar issues??? If yes do you have a workaround?
Thx a lot and best*
Raja
It's likely coil whine. Nothing you can do about it.
I occasionally get coil whine from my Strix 1080Ti's. If I start an app that changes the video mode, like a game or graphics app, the whine goes away. This is on my existing R5E. I removed the Strix cards to install in my new R6E, and replaced them with the original Matrix 290X's. No whine at all. I think coil whine is just luck of the draw.
