Rampage VI Extreme Omega and M.2 RAID problem
Lynkdev
I finally powered on this motherboard for the first time with the following:
10980XE
64GB DDR4 Trident Royal Mem
2x M.2 980 Pro 1Tb inserted into M2_1 & M2_2
First thing i did before powering on was a bios update to latest release using flash button on back.
I  wanted to configured RAID next and i may be doing something wrong here.
When i hit F11, i select PCH RAID, computer reboots and then i can only see 1 drive available to me to raid.
When i go back to AHCI mode, i can see both drives under 'Advanced\NVMe controller and Drive Information'
Did i miss a setting to turn on for both to be recognized in RAID?
5 REPLIES 5
Lynkdev
I see an option under 'Advanced\CPU Storage Configuration'
DIMM.2, M.2_2 and U.2 currently disabled but looks to be for VROC CPU RAID only?
VROC RAID on x299 platform limited only Intel SSD to setup. If you require bootable or OS drive its will require VROC Key ( Sell separately).
Samsung and other vendors didn't support. The PCH RAID setup may be working but it'll bottleneck by DMI 3.0.
W11 25H2 27858.1000 Core i9 7980XE 02007206 MCE ME 11.12.97.2614 R6E Modified BIOS 4201 SAMSUNG OG9 FW 1020.0 SSD 970 EVO PLUS 1 TB x 3 NVIDIA RTX 4090 GAME READY 576.52 64GB GSKILL DDR4 3200MHz JBL 9.1 Sound Bar DTS-X
cekeu
Level 12
Hi, do you have anything in the PCIe 3.0 x4 slot?
It seems to me that normally you should be able to configure a Raid 0 with M.2_1 and M.2_2. And that Intel drives are only required for the Dimm.2 module in Raid. I have the R6EE but I think it's the same principle for the Omega (maybe I'm wrong). Watch the capture below
Negative on the PCIe 3.0 x4 slot being used. I do have two 2080ti installed (just for testing purposes since SLI is practically pointless for games). These are in both of the x16 slots above the x4 slot. Any way i can check with cmds or bios to know if the M.2_2 slot is populated? thinking i need to reseat the M.2 in this slot now.
cekeu
Level 12
Hi, on my screenshots of the R6EE bios you will see how to activate the Dimm modules. However, restsugavan is right, we can only do a Raid with Intel disks.
On the R6E you can do a Raid to store with the disks connected to the Sata connections.
Also look at the storage capacities on the capture of the extract from the R6E manual.
