Rampage VI Extreme - Amperage (HI-Amp FAN and PUMP Connectors)
Beto556
I have already downloaded the manual of RE-IV and I am in doubt about the maximum amperage / voltage of 2 connectors (page 1-22), below:
66540
I have 5 Fans Coolers + Koolance pump (24V - 35W - 1,50 A).
Where should I connect the Koolance pump?
Raja
All of the onboard headers are 12V rated at 1A, while the H_amp header is rated at 12V 3A, which is good for 36W. Right on the wall, so I'd consider a dedicated psu for your pump.
Thank's Raja@ASUS 🙂
Brighttail
Level 11
I have the RE5 E10 and just for the heck of it tried my pump in the H_AMP and the W_Pump slot. Neither port read my EK d5 vario pump. CPU reads it fine. Even re-optimized it all, tried Auto and PWM as it is variable speed. Nothing on those two fan hubs.
Very odd.
Panteks Enthoo Elite / Asus x299 Rampage VI Extreme / Intel I9-7900X / Corsair Dominator RGB 3200MHz
MSI GTX 1080 TI / 2x Intel 900p / Samsung 970 Pro 512GB
Samsung 850 PRO 512GB / Western Digital Gold 8TB HD
Corsair AX 1200i / Corsair Platinum K95 / Asus Chakram
Acer XB321HK 4k, IPS, G-sync Monitor / Water Cooled / Asus G571JT Laptop
