Rampage VI extreme A2 and A9 problems.
Gushy
Hello,
someone can help amd tell me how to change the battery on Rampage VI extreme ?
I wanna reset the bios coz it gave me bios error A2.. i did try everything and noting work.
i try to reach the battery but i did not find a way to access that part. its covered by plastick.
The problem came when i just put my HDD and 2 m.2 disck's
When i put HDD have me error code A9, when remove HDD gave me A2 code.
And mobo does not post anymore.
Please help
BigJohnny
You dont need to pull the battery.
Shut down, pull power cord.
On the back top right is the clear CMOS button, depress and hold or 30 seconds. CMOS is now cleared.
