08-27-2018
09:57 PM
- last edited on
03-06-2024
08:14 PM
by
ROGBot
08-27-2018 11:31 PM
cristiancl wrote:
So, i've bought an Asus Rampage VI Extreme mainly for the water cooling features. I built my closed loop and went to configure it. But i didn't know that the WC features are non-existant. You can't config anything under BIOS, no shutdown if flow sensor fails, no fan config based on WC... You must use AI Suite.
My main problem is that if i set a fan curve, i can't choose the temperature sensor as a source, even though the water sensor is working and being detected.
https://imgur.com/a/J8Rhhkx
What is going on? how should i control the fan curve by the sensor?
Thanks
08-28-2018 01:43 PM
Homewrecker wrote:
Note sure about fan curves but you can use AIDA64 for sensor monitoring and have it sound an alarm and shut the machine down if the flow rate drops to a prescribed value. Been using that feature for years with no issues.
