05-24-2021 06:22 PM
06-07-2021 11:42 PM
Desertum_0 wrote:
I just flashed it without any issues however which USB hub is the one that i just updated?
06-09-2021 02:54 AM
06-09-2021 11:32 AM
BenJW wrote:
Thanks for sharing. On my R6EE (Encore), the FW update tool detected two out of three Asmedia controllers, for which the update apparently worked fine. Other than the changed FW version, I did not notice any changes.
According to HWiNFO, the R6EE comes with
- 2x ASMedia ASM2142 USB 3.1 xHCI Controller (each on a PCIe 3.0 x2 Link) <-- these are probably the ones that were updated
- 1x ASMedia ASM3242 USB 3.2 xHCI Controller (on a PCIe 3.0 x4 Link) <-- already supports USB 3.2 out of the box (even before update)
After the update, both ASM2142s are still detected as USB 3.1 devices, so I don't know what exactly the firmware update improved for those devices. Also, the linked station-drivers article does not mention any improvements such as support for more recent USB revisions ("USB 3.2") or faster speed. Do you have a source that specifies what exactly the update changes?
Since the 2142s are internally connected on PCIe 3.0 x2 links, they are physically capped anyways to max 16Gbps, i.e. they simply couldn't do 20Gbps on a USB 3.2 Gen2x2 connection even if the firmware update would bring support for Gen2x2. (Maybe this is different on other boards such as R6E or R6EO...)
Edit: So maybe this update only brings the "USB 3.2 Speed" improvement specifically to the 3142 controller (effectively advancing it to a 3242)?
06-09-2021 01:15 PM
everettfsargent wrote:
AFAIK there are no ASM2142 chips on the R6EE motherboard ...
https://www.ixbt.com/platform/asus-rog-rampage-vi-extreme-encore-review.html
In Russian (but using Google Translate and their inlined images) I get ...
Upper Left Hand Side (ULHS next to rear I/O ports or back side)
One ASM3242
One ASM3142
One ASM1543
One ASM1074
Lower Right Hand Side (LRHS next to SATA ports or front side)
One ASM3142
Two ASM1543
One ASM1074
(BTW, this is the most detailed review of the R6EE that I have found to date)
Except for the three USB 2.0 ports (one rear and two front) there are 17 USB 3.2 ports (twelve of these are USB 3.2 Gen 1) according to the Asus product manual (i. e. USB 3.1 is never mentioned).
The only way to know for sure is with a before/after test of all ports using a reasonably fast NVMe SSD for both internal/external file transfers with the proper I/O ports (Type A and C).
IMHO the R6EE does not require this firmware update if the USB 3.2 ports are as claimed in the R6EE manual.
06-12-2021 12:11 AM
06-09-2021 06:59 PM
