10-20-2017
06:50 PM
- last edited on
03-05-2024
09:43 PM
by
ROGBot
10-26-2017 07:18 PM
10-28-2017 06:10 PM
Shamino wrote:
i agree that you shdnt need to mess around at stock but without trying stuff cant really tell whats at fault. it does seem to behave like some temp sensitive CPUs under LN2 cooling which points toward the cpu.
the low uncore becos you said it happens at 2133 so i would start testing at 2133
sounds like this: set ai tuner to manual or xmp but set dram ratio to 2133 and reboot and hang.
but maybe start from clean scratch
latest bios = 1002, latest oled f/w from website updated
remove AC power and let mobo drain completely for like a minute.
plug in sound card
connect ac power after plugging in sound card.
clear cmos and power on.
set xmp but set dram ratio 2133
keep resetting and see if hang.
if yes:
set aux2/input reset volt/preemphasis/uncore voltage offset as stated
keep resetting
if hang still:
set bclk to 99.5mhz
keep resetting
another thought was that plugging in the soundcard with standby power still coming in could have caused it.
10-26-2017 08:10 PM
10-29-2017 08:14 PM
10-29-2017 09:08 PM
10-29-2017 10:09 PM
Homewrecker wrote:
This is beyond basic tuning IMO. Other people have reported using the same memory kit with no issues. I don't mind playing with BIOS settings and am far from being a 'Plug and Play' person but having to jump through so many hoops just to get the system to boot is a little ridiculous. At times the system wouldn't even boot at the default speed of 2133Mhz. Hopefully the next board will yield better / more stable behavior.
10-29-2017 10:37 PM
Raja@ASUS wrote:
You are corerct that memory tuning is far from basic. The faster the kit, the more complicated it can be.
11-22-2017 08:30 PM
