01-15-2018
07:03 PM
- last edited on
03-06-2024
09:30 PM
by
ROGBot
01-18-2018 04:46 AM
Thireus wrote:
I finally have the answer to the freezing issues I've been having! And I’m quite confident this is an issue with the Asus Rampage VI Extreme motherboard or maybe with the BIOS!
On the Asus Rampage VI Extreme, enabling both XMP and Core C-State will cause the system to freeze or crash after a few hours. When on stock settings, these two options are incompatible, at least on BIOS 1004. Therefore, I would like to request Asus to have a look at this technical issue, which clearly appears to me to be a board instability.
The following BIOS setting is responsible for the system freezes when XMP is enabled:
Autonomous Core C-State [Enabled]
All other settings (except XMP and the above) should be on stock!
To reproduce the issue and cause system freezes that occur as soon as possible after system boot on Windows 10, one can run Prime95 v26.6 with the following Custom Torture Test settings:
Min FFT: 8
Max FFTP: 4096
Run FFTs in-place: Checked
Time to run each FFT size (in minutes): 1
Also, running 2 instances of memtest from HCI Design: http://hcidesign.com/memtest/, with the maximum available memory might help trigger the freeze when running Prime95 in parallel. Although, when freezes occur memtest should not find any memory errors! (unless you have bad memory, which is not my case as I've already tested my memory)
Anyway, with the above C-State enabled, XMP enabled, and everything else on stock, the system should freeze after several hours of stress test, which should freezes after a maximum of 2h elapsed on the stress test which should be equivalent to 230% of memtest coverage. However, I have noticed that with other options enabled, such as the ones I mention in my first post, these freezzes can instead be system crashes (BSOD) in which case the Windows minidump after BSOD will be mentioned that this is memory related, sometimes it will be MEMORY_CORRUPTION_LARGE, sometimes MEMORY_CORRUPTION_ONE_BIT_LARGE. Crashes/Freezes can also occur much sooner too! If you wish to test your system stability with XMP and C-States enabled, I would recommend to please make sure to have everything on stock settings before enabling both XMP and Autonomous Core C-State only in the BIOS, that way you’ll only get system freezes!
As for now, I will leave "Autonomous Core C-State" on Auto (which I assume is in reality disabled). I will also write Asus an email about the issue, and hopefully their technical team will be able to fix this bug in a future BIOS release.
I was also curious to know if others had similar issues and decided to Google about it, and I found people who reported in the past that enabling C-States was incompatible with XMP and would cause their system to crash after several hours, which happens to be the issue I have with the Rog Rampage VI Extreme: https://vip.asus.com/forum/view.aspx?board_id=1&model=P7P55D+LE&id=20150520045828228&page=1&SLanguag...
Does anyone understand why, when enabling C-States on my config and with XMP enabled, the system would freeze after several hours? (When XMP is disabled C-States are perfectly working fine)
@Raja, do you know if this is something that can be looked at by the technical team? That appears to be a bug to me, more than just incompatibility. Or at least the BIOS should prevent the use of C-States (or maybe these specific settings) when XMP is enabled.
Also, I would like to add that from what I can remember from my previous build which involved an x99 Prime Deluxe II with an i7-6950X processor I didn’t have any problems having C-States and XMP work together!
01-18-2018 12:36 PM
Raja@ASUS wrote:
Given the system is running XMP (it is overclocked), the default voltages may not be sufficient for stability when the CPU comes out of power saving modes. You can debug by tuning the voltages (Vcore, VCCSA, VCCIO, Cache voltage, VCCU) somewhat. With increased data rates, you're eating into the margin for stability.
01-17-2018 04:21 PM
01-18-2018 12:36 AM
Thireus wrote:
I would like to add that people are having similar freezing issues on the following threads:
https://rog.asus.com/forum/showthread.php?97318-UEFI-1003-for-the-Rampage-VI-Extreme-Changes-are-fre...
https://rog.asus.com/forum/showthread.php?98662-Rampage-Extreme-VI-causing-computer-freeze!
https://rog.asus.com/forum/showthread.php?46997-Asus-Extreme-Rampage-IV-freezing
They might not all be related, but there is a good chance some of their issues are linked to what I found and detail in my previous posts.
01-18-2018 04:19 AM
Silent Scone wrote:
The first two were resolved by flashing to the newer BIOS revision available at the time, the last link is not even on this platform. Safe to say they're not related, unless you're encompassing all memory instability problems under the same roof.
It's also worth pointing out that I'm not aware of anyone else, including myself that has had to adjust this setting in order to maintain stability.
01-18-2018 08:20 PM
01-20-2018 01:06 PM
