12-11-2018
04:56 AM
- last edited on
03-05-2024
08:29 PM
by
ROGBot
12-11-2018 05:30 AM
Epic-Shot wrote:
My system Randomly Freezes and I cant find any reason why. Bios is updated to 1603 and all latest drivers. Does anyone no what I can do?
Here is my spec's
Processor: Intel Core i9-7920X
Motherboard: ASUS ROG RAMPAGE VI EXTREME
System Memory: DOMINATOR® PLATINUM 64GB (4 x 16GB) DDR4 3200MHz
Power Supply: 1200W Corsair AX1200i
Storage Set 1: 1x SSD M.2 (1TB Samsung 970 PRO)
Storage Set 2: 1x SSD M.2 (1TB Samsung 970 PRO)
Graphics Card(s): NvLink 4Sot Nvidia's GeForce RTX 2080 Ti 11GB (Founders Edition)
Custom Cooling System (2x Graphics Cards + CPU)
Reservoir Pump Combo: EK-XRES Reservoir Pump Combo D5
Radiator: XSPC EX Radiators EX560mm Quad Fan Radiator, EX420mm Triple Fan Radiator, and EX280mm Dual Fan Radiator
Water Block GPU: 2X EK-Vector RTX 2080 Ti RGB - Nickel + Plexi
Water Block GPU: Back Plate: EK-FB ASUS ROG R6E RGB Monoblock – Nickel EK-Vector
Water Block GPU: Terminal: EK-FC Terminal X4 – Plexi
Water Block CPU: EK-FB ASUS ROG R6E RGB Monoblock – Nickel
Chassis Fans: Corsair ML PRO Series (15 Fans Total)
Corsair Commander pro x 3
Operating System: Microsoft Windows 10 Professional (64-Bit Edition)
12-11-2018 05:37 AM
restsugavan wrote:
Oftenly Checking your RAM stick first.:o Trying to XMP setting.
12-11-2018 05:43 AM
Epic-Shot wrote:
That was the First thing I did! That did nothing to solve the issue. Ran Memorytest86
12-11-2018 07:48 AM
restsugavan wrote:
Testing with single GPU once with Realbench ?
12-12-2018 04:29 AM
12-11-2018 08:58 AM
12-11-2018 10:53 AM
JustinThyme wrote:
Is BIOS set for optimized defaults?
Stupid question but is GPUs in correct slots?
Have you tried starting with one stick of ram and adding the others one at a time?
Are the sticks in the correct slots?
12-11-2018 11:24 AM
12-17-2018 01:19 PM
