dimm.2 problem
Arbab_Arsalah
I'm using a x299 extreme motherboard with a i7 7820x I installed a m.2 ssd into the motherboard slot and one into the dimm.2 but the one on dimm.2 does not show up even in bios after updating it, i am also using 2 1080 ti's in slot 1 and slot 3. I am not sure what to do...
5 REPLIES 5
Hopper64
Level 15
That’s a 28 lane CPU. I think you have exceeded the PCIe lane allocation with your hardware.
**https://ark.intel.com/products/123767/Intel-Core-i7-7820X-X-series-Processor-11M-Cache-up-to-4-30-GH...
MZ790AE Bios 1703, GSkill F5-8400J4052G24GX2-TR5S, 14900KS, EKWB D5 TBE 300, Seasonic Prime TX-1600 ATX 3.0, Asus Strix 4090 w/ HK block, Phanteks Enthoo Elite, Asus Claymore 2, Asus Gladius 3, Asus XG349C, Crucial T705, Windows 11 Pro
Mr__Fox
Level 12
What are your BIOS settings? I have mine set to AHCI with all CPU storage options set to disabled and all four of my Samsung NVMe drives work fine (two on one DMM.2 card and two on the other DIMM.2 card).
76931
Wraith // Z790 Apex | 14900KF | 4090 Suprim X+Byksi Block | 48GB DDR5-8600 | Toughpower GF3 1650W | MO-RA3 360 | Hailea HC-500A || O11D XL EVO
Banshee // Z790 Apex Encore | 13900KS | 4090 Gaming OC+Alphacool Block | 48GB DDR5-8600 | RM1200x SHIFT | XT45 1080 Nova || Dark Base Pro 901
Spectre // Z790i Edge | 14900KF | 3090 Ti FTW3 | 48GB DDR5-8200 | RM1000e | EK Nucleus CR360 Direct Die || Prime A21
Methuselah // X79 Rampage IV Gene | Xeon E5 1680V2 | Titan | 32GB DDR3-2400 | GameMax 850W | EK Nucleus CR360 Dark || Prime AP201
Half-Breed // Dell Precision 7720 | BGA CPU Filth+MXM Quadro P5000 | 4K Display | Sub-$500 Grade A Refurb | Nothing to Write Home About
Hi! Does this mean, that you can insert TWO DIMM.2 cards on Rampage VI motherboard, making a total of FOUR NVMe M.2 SSDs on the two DIMM.2 cards? I'm a bit confused, becouse in the images I see only one DIMM.2 slot on this motherboard. Is there another one, that I missed?
Sorry, it's my bad, now I see you use Apex and not Extreme.
G75rog
According to the manual your ssd should be installed in M2_1 which is the socket next to the memory. You can select PCH for it in the Bios.
