07-14-2023 06:46 AM
Remove everything out except CPU.
Replace everything except CPU from your R6E.
Remove backplate and every screws to open ROG Cover
Remove backplate and all screws to unlock ROG Armor
Remove CMOS battery holder cable from the board.
Remove R6E battery holder and it cable away from the board.
Installing the Notebook CMOS CR2032 with 2-pin Big Size.
Installing Notebook CMOS CR2032 battery with 2-pin Cable Big Size instead.
Setting BIOS date time and other config F10 Save setting and Exit
When boot up you'll get " CMOS Error " on OLED screen. Don't be panic hit F1 to enter setup.
Enjoy your R6E. Enter date and time with all your preferred setting value on R6E BIOS.
Then F10 Save setting and Exit.
Enjoy your rigs.
07-15-2023 03:05 AM
nice work!!!i replace mee to the battery!!i have one question for you,can you run the 7980xe on cinebench r23 test 10minutes and show here the picture here on hwinfo VRM temps?thanks a lot
07-15-2023 05:50 AM
08-15-2023 10:43 PM
Modified BIOS had recently Intel microcode protection against Intel " Downfall " vulnerable issue.
It always contain update modules of firmwares that bring more performance than original BIOS. 🎁😃🎁
08-17-2023 01:23 AM
I have some issues when powering down the machine completely and disconnecting from the wall, on next boot it does multiple boots and finally prompts for F1 to restore the BIOS settings. Is this a symptom of a bad battery. My board VRM is watercooled so no easy way to take it out. 😞 I've been trying to play around with memory settings and boot voltages etc but nothing seems to be helping. Can't measure the battery without taking it all out.
08-17-2023 03:12 AM
Install HWiNFO and check your battery there
08-17-2023 02:22 PM
Thanks, mine shows 3.168 as minimum. So it might not be cause of the issue 😞 I wonder how accurate this reading is though.
08-17-2023 10:23 PM
Well..noticed the Windows clock has always also stopped to the time of powering down the PC completely so it still sounds related...need to find time to take it all out, not anytime soon though.
08-17-2023 10:27 PM
Hello,
For what it costs and the age of the system it's probably worth changing anyway. Certainly sounds like the issue if it's not retaining date & time.
