Bios is updating LED firmware
Hopper64
Level 16
I had flashed bios 1503 with no issues. Just noticed this statement today right before the bios splash screen:
"Bios is update LED firmware. Do not shutdown or restart to prevent system failure."
Everything works well otherwise. Don't know what the cause is here. Any ideas?? Thanks.
MZ790AE Bios 2107, F5-8400J4052G24GX2-TR5S, Intel 14900KS, Optimus Signature V3 Block, Heatkiller Tube 200 D5, Seasonic Prime TX-1600 ATX 3.1 Noctua Edition, Asus 5090 Astral, Phanteks Enthoo Elite, Asus Claymore2, Asus Gladius 2, Asus XG349C, Samsung 9100 Pro, Windows 11 Pro
14 REPLIES 14
Hopper64
Level 16
Oh, just remembered I had just installed the new Aura software yesterday. That may be the issue?
Hopper64
Level 16
Looks like it’s due to aura, but how to fix it is the next question:
**https://rog.asus.com/forum/showthread.php?104892-AURA-SYNC-1-06-95-Report-Issues-Here/page3
thr23
yeah this happens to me as well. don't think there's much we can do, gotta wait for Asus to fix this.
Hopper64
Level 16
Figured. Doesn't seem to cause any problems. Quite strange. Thanks.
Abaidor
Perhaps it was always happening in the background and is only now that it's been reported (by accident).
Asus Rampage VI Extreme | i9-7940X | 64GB Trident Z RGB 3600 | Asus Strix 1080Ti OC | Samsung 960 Pro 512GB | WD Gold 10TB | WD Red 4TB X 2 | PSU Corsair AX1500i | Custom Water Loop - RAD MO-RA3 420 Pro | EK Monoblock | Phanteks GPU Block | Heatkiller 200 Tube RES | EK Dual D5 Revo Pumps | 9 X Corsair ML 140 Pro Fans on RAD | | Bitspower Fittings Black Chrome | Cooler Master Cosmos 2 Modded Case | Silent WIngs 3 120mm Intake |
No this is recent. I check the post screen often with bios updates which did not happen last week with 1503. Goes with being one of those Anoraky types that Raja talks about around here from time to time. 😄
What I meant was that perhaps it was happening in the background "WITHOUT" any indication / message on screen so you wouldn't know anyway.
Yes, I see what you mean. I would think that’s possible. Someone forgot to remove that part from the code written for the update. *
Sprayingmango
I was coming here to post this exact same thread lol!
I updated to the new Aura and 1503 as well, getting the same message.
