ASUS RVIE ENCORE 6 pin power connector?
shadowman007
Noticed ASUS Rampage Vi Extreme Encore had a 6 pin power connector as well as 2x 8 pin connectors. Heard of a 6 pin gpu connector to connect to the gpu but not a 6 pin connector to connect to the motherboard. My question is would I need to connect a 6 pin as well as the 2x 8 pin cables?
83215Â*
27 REPLIES 27
tistou77
Level 14
Indeed, the PCIe 6pin are wired like the Encore 6pin
A PCIe 6pin cable is therefore good
Sorry for my english 😄
Case: Lian Li A77F
MB: Rampage VI Extreme Encore
CPU: i9 10980XE
RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
GPU: EVGA RTX 2080ti XC Ultra
PSU: Seasonic Prime Ultra Titanium 1000W
OS: Intel Optane 905P PCIe
DATA: Samsung 980 Pro
SOUND: Asus Xonar Phoebus
Desertum_0
Quite confusing.
Can I just use any PciE 6 pin cable (GPU cable) so I can connect to this 6 pin power plug?
I was hoping to just connect the 2x 8 pin plugs and call it for the day.
Edit: It seems that after all it was a typo from asus and that 6 pin is not a EPS power plug but rather a normal 6 pin GPU plug.
Please confirm that this is correct.
Thanks
Desertum_0 wrote:
Quite confusing.
Thanks
Yes, you can use the PciE 6 pin cable (GPU Cable) I used it too 😉
Excelent new Tistou.
I see you are using the encore now.
Do you find it better than the Rampage VI extreme?
I also want to ask you where is the right M.2 slot to install the intel Optane M.2 ssd?
Merci.
Merci.
Frankly, I did not look for the OC (samen settings with R6E)
The VRMs heat up slightly less than those of the R6E (watercooled)
On the other hand the management of the voltageof the rams is catastrophic
The Samsung M2 is installed on the DIMM.2 and the optane 905P is in PCIe
Case: Lian Li A77F
CPU: i9 10980XE
It is a beast of a board but is still very buggy, not many BIOS updates from ASUS except yours 🙂
I also wanted to ask you if I could Raid 2x Intel 900p in Raid 0 ?
Currently I do not have any Intel SSD M.2 but rather 1 Samsung 960 PRO and 1 Samsung 970 Evo pro.
Thanks my friend.
tistou77
Level 14
Same for me, 6pin for GPU 😄
Case: Lian Li A77F
CPU: i9 10980XE
tistou77
Level 14
I think you can do a RAID0 but I'm not at all "good" in this field
sorry my friend
Case: Lian Li A77F
CPU: i9 10980XE
