Asus R6e omega aida 64 low ram write speed
MirceaForce
I'm now running the same confing on omega but have some issue with aida 64 engineer version see here
On my older r6e did not have the full version of aida 64 so did not know the write bandwidth speed
I'm running the latest bios 3105 did already reset bios, load optimize defaults ,the ram is the slots are like in the asus manual recomended settings, but the write speed to slow
I did also xmp non xmp . but the write speed .....still the same for 3200mhz F4-3200C14Q-32GTZR, the ram is qvl checked in asus
the motherboard is brand new did install ram twice checked for dirt or other before install
Maybe there is a bug with aida 64 others test for ram bandwidth? or is because cpu ? see review on web but they use different cpus more powerful
i did disable all power savings in win or bios
did all stability tests, prime, cpu id, aida all pass
Is there something to concern ?
here is pass mark result
in what i read here I think is the cpu
https://www.guru3d.com/articles_pages/intel_core_i9_7900x_processor_review,13.html
so for i9 7900 is 52gb write my i9 7920x almost 60gb and so on
correct me if I'm wrong
MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34
F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
18 REPLIES 18
DEJ915 wrote:
What? You think 7900 cannot do 100? I pulled out my old 7820 system and adjusted 5 settings and get 102 read 95 write with 4ghz on ancient OCF beta bios.
I have i9 7920x and cannot pass 60gb write with ram 3200mhz , where is the truth ?
what settings did you do ?
On my side I did xmp original 3200mhz and the cpu at 4.0 Ghz
lLegendaary wrote:
You'r true also what is propose of using AIDA64 if i can test it manually ?
Can someone explain ?
Also what i know from test to other on same cpu may vary due heat - temp ... but should be around same number or below it little bit
what cpu do you use ?
9980xe
i honestly don't care about AID or any benchmark apps
I just want to see real performance by playing/watching movies/ editing ... also u may notice some windows update may effect your hardware little but as i told you it should be around the numbers ...
how do you test your ram manually ?
restsugavan wrote:
It may be AIDA64 issue mate :: https://forums.aida64.com/topic/5514-cache-and-memory-analysis-core-i9-10980xe/
I think is the cpu because is only 60GB capable from that review that I posted ..
restsugavan
Level 15
86228
For Reference 7980XE 2.6 GHz no overclock AIDA 64 5.25.5476 BETA
Windows 10 2021 H2 Insider Preview 20206.1000
W11 25H2 27842.1000 Core i9 7980XE 02007206 MCE ME 11.12.97.2614 R6E Modified BIOS 4201 SAMSUNG OG9 FW 1020.0 SSD 970 EVO PLUS 1 TB x 3 NVIDIA RTX 4090 GAME READY 576.15 64GB GSKILL DDR4 3200MHz JBL 9.1 Sound Bar DTS-X
vmanuelgm
Level 11
7900x can do more than 100GB in write, this is 3800 C16 in a Gigabyte:
Asus x670e Hero, 7950x, TG 7000, Master 4090, 970 PRO, 860 EVO, Intel 750,
SN850, SN750, 840 Pro, 2xSkyhawk 4TB, Pioneer S12U
EVGA T2 1600, Silverstone TJ11, Custom LC, Acer Predator x35, Philips OLED
even with this oc the write is to high for that cpu I cannot pass 60gb write in aida64 with 4GHZ and ram 3200mhz
