Asus R6e omega aida 64 low ram write speed
MirceaForce
I'm now running the same confing on omega but have some issue with aida 64 engineer version see here
On my older r6e did not have the full version of aida 64 so did not know the write bandwidth speed
I'm running the latest bios 3105 did already reset bios, load optimize defaults ,the ram is the slots are like in the asus manual recomended settings, but the write speed to slow
I did also xmp non xmp . but the write speed .....still the same for 3200mhz F4-3200C14Q-32GTZR, the ram is qvl checked in asus
the motherboard is brand new did install ram twice checked for dirt or other before install
Maybe there is a bug with aida 64 others test for ram bandwidth? or is because cpu ? see review on web but they use different cpus more powerful
i did disable all power savings in win or bios
did all stability tests, prime, cpu id, aida all pass
Is there something to concern ?
here is pass mark result
in what i read here I think is the cpu
https://www.guru3d.com/articles_pages/intel_core_i9_7900x_processor_review,13.html
so for i9 7900 is 52gb write my i9 7920x almost 60gb and so on
correct me if I'm wrong
MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34
F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
18 REPLIES 18
restsugavan
Level 15
It may be AIDA64 issue mate :: https://forums.aida64.com/topic/5514-cache-and-memory-analysis-core-i9-10980xe/
W11 26H1 28020.1546 Core i9 7980XE 02007206 MCE ME 11.12.98.2655 R6E Modified BIOS 4201 SAMSUNG OG9 FW 1020.0 SSD 970 EVO PLUS 1 TB x 3 NVIDIA RTX 4090 GAME READY 591.86 64GB GSKILL DDR4 3200MHz JBL 9.1 Sound Bar DTS-X
You'r true also what is propose of using AIDA64 if i can test it manually ?
Can someone explain ?
Also what i know from test to other on same cpu may vary due heat - temp ... but should be around same number or below it little bit
Test with your RVIE and see if it is the same result. You can copy over your AIDA folder it will stay activated.
I have already told you that I don't have that board ...
Ah I missed that sorry. My 9800x has lower write speed in AIDA compared to my 7900x, I thought it was my new Omega I got but I tested it on my Apex, Asrock OCF and EVGA Dark with the same manual settings and the results were the same on all 3 other boards so it must be the cpu in my case at least. I tried different bios on omega as well at first and it made no difference.
what was your memory write speed in aida64 for 7900x ?
I didn't check the timing setting so they are probably different than from 9800x but I took a screenshot so you can compare and do manual test on yours if you wish.
https://imgur.com/a/brCKm1v
edit: I updated the picture album with 2 9800x settings, one with c16 and then the same settings from RVIE copied over.
the write are to high for a 7900x even he does not have capability
What? You think 7900 cannot do 100? I pulled out my old 7820 system and adjusted 5 settings and get 102 read 95 write with 4ghz on ancient OCF beta bios.
