Windows Power Setting at Power Saver With Clock Speed at Idle High
Super_Gnome
Level 11
My rig power setting is set at Power Saver, yet the clock speeds (and also temperatures) are very high--like at 4100 MHz at idle with the CPU core temperatures very high at idle unless the fans are blasting at full. There is no dust at all in the system, and it runs a water cooler, a Ryujin in fact. A virus scan done by a pro company found no virus, nor did any other virus scans. Task Manager shows nothing is using the CPU in any way a lot at all.
I did install the latest BIOS though, 3006 (Rampage VI Extreme Omega MB), which came out about a week ago, but the BIOS is set to the default settings, with no overclocking.
Can anyone help with this issue?
0 REPLIES 0
