MoKiChU
Level 40
168 REPLIES 168
This last Armoury update completely screwed my stuff. They were working great for atleast 6 mths till i did the update to the latest version. Now my Spatha suddenly seems to lose connection to the dock for a split section causing the cursor to not move....which completely killed my fps gaming. Also, it will not keep assigned button commands and wants to say diabled when i got to check them in the software. I've tried resetting them to default and the configuring them again like was suggested by someone else on here....that doesnt work. To top it off...I went to see if a new update was put out to fix all this and it said my Claymore needed a firmware update...but guess what, firmware update fails EVERYTIME. Ive tried all my USB ports and still the same thing. I think they screwed the pooch when the teamed up with Activision to add support for stupid black ops 4 environmental lighting...everything having to do with that game is garbage right now. I dont know what happened, but it screwed my stuff. Im going back to the last version to see if that helps.
Check your inbox. I have PM'd you the latest Spatha firmware (1.72), try a manual update.
_____________________________________________________________
FPS, Racing, and VR Gamer / Tech Enthusiast / ROG Admin
MasterC
Community Admin
Community Admin
iliya wrote:
When will you fix this error?68501
The left button must be assign to a button in case the user ends up with no left-click functionality at all. I will let the team know some people (perhaps left-handers) are requesting to switch to another button. A duplicate must be assigned first though, we'll look into it.
Thx for answer!
There is no such error for the right button.
In the very first versions of the software, there was no such error.
Best regards,
Iliya
MoKiChU wrote:
Hello everyone,
Version 1.02.23 of ROG Armoury has just been released : http://dlcdnet.asus.com/pub/ASUS/mb/accessory/ROG_Spatha/ROG_Armoury_v10223.zip
And, none of my issues are fixed in this one either.... Still causing issues with AURA (Case lights change/flicker and configuration changes totally when opening Armory) my mouse profiles still aren't saved properly, and the UI still isn't updating the currently selected options, when selecting "base, scroll wheel, logo" on the LIGHTING area, when "Sync all areas" is off...
each 'update' is no different than the last, and honestly things have got worse though the updates...
ROG_Armoury_v10223
Fixed Armoury installation issue in specific environment
Are you kidding?
You can not fix a significant errors?
Add the option to repeat macro while holding the button it would be really useful thanks
namoi
What an amazing changelog...
Still no compatibility with Aura?
Sent from my XT1562 using Tapatalk
