System Reserved E drive?
squigy7
I reinstalled win7 and now I have a c drive and an e drive called reserved... why is it seperated and how do I get it back on the C drive so I can utilize the 99.9mb of SSD space on the drive?
4 REPLIES 4
X-ROG
Level 15
Squiggy:
Go to Computer --> organize (top left) --> folder options --> view (tab) --> Under hidden files and folders select 'don't show hidden files and folders'.
There, gone 🙂
It's an automatically created and reserved space for your file list used by Windows. You cannot use it or move it.
It is the partition that Windows makes for GPT and EFI related stuff. If you were to open if - be careful! - you will find that it contains a bunch of stuff with extensions like .efi.
I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
http://rog.asus.com/forum/group.php?groupid=16
We now have 178 people whose systems will not break! Yippee! 🙂
LINUX Users, we have a group!
http://rog.asus.com/forum/group.php?groupid=23
squigy7
It's already selected and still showing.
squigy7
Okay I will just ignore it I just wanted to make sure that disk space is still usable on it.
