Substitute cooling fan
raymak
im using g551vw and my cooling fan has been making funny noises and it seems its not blowing air the way it use to
now my country is **** and i cant find my laptops fan model
[i bought a fan for g551jw but didnt fit. didnt even notice the V and J till then]
and i was wondering is there any other fan model from other laptops or even companies other than asus that i can use instead? (it fits with the same voltage and power[ 5v-2.25w ] )
thank you.
KITT_2013
you can order from this website: https://www.powerlaptop.ro/products/cooler-laptop-asus--g551vw-mufa-4-pini.html?gclid=CjwKCAjwkJj6BR...
I see that it ships internationally. It is in my country so I trust it.
or always from aliexpress 😛
