[SOLVED] STRIX B450-E: system worked fine for 6 months , now QLED yellow, no display
zerbes
i worked with my ASUS ROG STRIX B450-E fine for half a year now. Yesterday the system shutdown from running alone (recognizing later when i went back to work with it) and can't be restarted.
The onboard-QLED is yellow, no output to screen etc. I did not change anything on hardware-side this 6 months, i updated the BIOS 1-2 weeks ago but after that the system also worked. All fans seem to work.
I checked the RAMs, changed their position, tried only one of the two i have installed but nothing changes, system remains with QLED yellow and no display.
Does anyone of you have an idea how to proceed finding the cause?
Thank you
Steffen
[SOLUTION] it was the RAM. I tried again and with one of both RAM-modules only it works. No idea why it did not work when i tried first earlier. This means: always try twice with the RAM-modules!
0 REPLIES 0
