02-15-2017 10:03 AM - last edited on 03-06-2024 08:48 PM by ROGBot
02-16-2017 09:15 AM
02-17-2017 06:21 AM
Arne Saknussemm wrote:
That's why I pointed you to that thread. Xmp is obviously setting gen 2.0....
I would just set RAM up manually...and be done...
02-17-2017 06:08 AM
02-17-2017 06:31 AM
jab383 wrote:
To set RAM manually, start with the working profile you have for the CPU and peripherals like the 960. Select the DRAM clock and enter the primary timings at XMP values. You can leave other RAM settings at AUTO unless you want to try them manually. That should avoid unintended settings.
02-17-2017 06:33 AM
07-11-2017 10:41 AM
sonar wrote:
HI.
So I have the latest bios for my motherboard and set the M.2 strap to pcie instead of Sata in the bios. Disabled CSM downloaded windows directly to a usb and installed windows 10 from the bios usb UEFI. Download the new Magician and... Samsung magician performance test shows my 960 pro 500 GB read speed at 1800 and write speed at 1635 when its supposedly rated and tested at 3500 read and 2500 write. The PCIe Gen shows 2 x 4. After that i have 1000000X installed windows again and still shows the same slowly write and read speed. :(:(:(
What am I missing? Is there anything else I can do?
Thanks in advance
07-11-2017 10:43 AM
Hawkstorm wrote:
I have the 2GB 960 pro and I'm having the same problems, and the same results.
08-02-2017 11:29 AM
08-04-2017 01:22 AM
Blue11 wrote:
The new version of Samsung's Magician has some remarkably onerous terms in what they want you to agree to. Be sure to read them if you deploy it.
To summarize: They can siphon endless data off your drive, including but not limited to what programs you have installed, how often you use them, what kinds of things you order online, your contacts list, your calendar, your browser history, any personal data they can find, and on and on. They are then allowed to use this data in any manner they wish, including selling it or bartering it to third parties about whom you know nothing.
If you deny the software online access through your firewall, it won't load.
Once I actually read the terms, I uninstalled it and deleted every vestige of it from my system.
Know what you're getting into.
08-04-2017 12:26 AM
Hawkstorm wrote:
I have the 2.2 Samsung driver installed but it makes no difference with or without it.
