Rampage V extreme 1 broken pin
Aarbron
Hello all 🙂
I have an asus rampage V extreme with one broken pin,
i don't have a cpu to test if the motherboard boots or not and i 'd like to know if someone has information about this pin. it's the rightmost pin before the plastic groove.
I tried to find a diagram but without results yet.
Thank you
here it is in red (you can zoom)
73394
11 REPLIES 11
Rob_W_
Level 12
Can you put pic up without red dot?
Arne_Saknussemm
Level 40
P53 here... there is a map...but it looks like it is looking up through the socket from below orienting the triangle...
https://www.intel.com/content/dam/www/public/us/en/documents/guides/core-i7-lga2011-3-tmsdg.pdf
Looks like AJ 17 from this doc that gives vss which is connected to ground (p76)
https://www.reddit.com/r/buildapc/comments/3oi02c/lga_20113_pin_layout_diagram/
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/core-i7-lga2011-3-datasheet-...
I can see at least one other bent pin in there
73415
thanks for the answers.
If this broken pin is not connected to the ground anymore, is is this problematic for the normal functionning of the mainboard/cpu ?
can it produce instability ?
Arne_Saknussemm
Level 40
I'm not aware of any pin that is there for no reason so, yes, I think that socket is liable to some problem. I wouldn't chance a CPU in that socket unless I was prepared to accept the worst possible outcome for CPU and board
ok thank you, I will return this motherboard to the ebay seller.
Aarbron
last question : can someone tell me witch pin is in red please ? (by using the diagram legend)
for me it's BW-42 but im not sure. : 73479
thank you
Arne_Saknussemm
Level 40
I think that is BV 42...difficult to tell from that diag.
But to be clear that is not the pin you indicate in first post right? that pic is 180 degrees rotated compared to your pic of the socket
i think you're right i need to rotate it. so it becomes AL17 or AJ17 as Rob W / Arne says
Rob_W_
Level 12
AL 17 I think.
