RADAR_PRE_LEAK_64 reports in event viewer - problem with rams?
sde444
Hi. So first my pc.
My rams are Kingston Hyperx 16gb 2x8 DDR4, 6700K,Asus Z170-P, SSD Crucial Bx100 256GB and Windows 10.
Everytime i am opening some application which is fine and opening. But on event viewer i get : RADAR_PRE_LEAK_64 errors. Applications are opening fine but windows 10 reporting this as RADAR_PRE_LEAK_64 in event viewer.
If games not crashes and i have that logs in event viewer do something, or leave it alone?
I have that radar errors in event viewer almost everytime when i am opening some game or benchmark , thats all. But not crashing.
Example from BlackOps3:
Like i said i dont have crashes , but only that warnings on event viewer. Thats all. Should i worry? Something with rams, ssd? Should i check memtest86 or that will be waste of time?
7 REPLIES 7
TeMagic
Your PC is exhausted, box needs new CPU and Motherboard. The Z170-P is all tear and has mutated the CPU. You should claim warranty on the motherboard, since yours is a TOA.
Conspiracy is nothing!
What you mean? Its something with motherboard, cpu ? Or what you talking about?
I run memtest86 for 5 hours and no errors.
Yes but why sometimes GTA V.exe, 3dmark.exe ,not only Black Ops 3,and other apps trigger that entry in event manager. ??
Nate152
Hi guys
The RADAR_PRE_LEAK_64 is caused by a program that has a memory leak, in this case it's Black Ops 3, if you're not experiencing any problems you can ignore it.
Nate152 wrote:
Hi guys
Just BS.
Nate152
Hmmm... I'm not sure but something is triggering it.
You could try a system restore to a point where it wasn't happening or if it's not too big of a deal do a windows reinstall and see if it goes away.
So its something with hardware ?
Nate152
