R9 290x DC20C Liquid Cooling?
Valaska
Hey there ASUS and other peeps! I need some help picking my new GPU (pairing with the Sabertooth!) and one of the deciding factors is compatibility with liquid cooling.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121840 Isn't reference but is one of the better rated cards out there! So I am slightly worried about it being compatible with liquid coolers, I have done as much digging as I could but have found little more than this;
http://www.coolingconfigurator.com/step1_complist?gpu_gpus=1295
Which doesn't exactly inspire a lot of confidence in saying if it can or can not... It's just kind of saying you can buy the two... It almost looks like the visually are going "Yeh, yeh mebeh that'd fit there eh?" so yeah, you guys know if it can actually fit? Thanks peeps and peepettes!
ConkersGrillfor
Yes, those EK-FC R9-290X DCII blocks are designed for the Asus R9 290X DCII (OC).
In the installation manual you see under step 1 the PCB Layout of the R9 290X DCII, which is similar to the OCed model, that you can see in this review from ocaholic if you scroll down a bit. 😉
Desktop: Xigmatek Elysium | Rampage IV Extreme | i7-3960X | G.Skill 32Gb DDR3 2133Mhz|fastest Asus MarsII on the planet:cool: core 950Mhz| Kingston HyperX SSD 240Gb + 300Gb Intel 300series SSD + Velociraptor 600Gb + 3TB HDD | Enermax Maxrevo 1500W| 3xDell U2412m |
Laptop: Samsung 940X3G | i7-4500U | 8Gb RAM | 256Gb SSD | 13.3" 3200x1800 |
