Hello,
I am working on my PWM setup with a Phanteks hub in the case manual it describes that the PWM hub should be connected to the CPU connector because that is in most cases a true PWM signal, right above the CPU fan connector is a Case Fan 2 connection the Case Fan 1 connection to far for nice cable management.
While looking at the manual i could not find anything about what PWM signal each connector has.
A bit hesitant to connect my CPU fan with my case fans so i hooked up the PWM hub the Case Fan 2.
But what signals does the Prime B350 offer for PWM?
Cheers,
