monitor only works in safe mode
Aledjo
Product Name: asus maximus v formula
Operating System: Microsoft Windows 10 (64-bit)
this be my prob gurus
I removed my gpu gtx 660 and connected my onboard graphics to my monitor usiing hdmi.to.dvi d cable and it worked perfectly. after Installing intel graphics drivers. the monitor went black and then sleep mode. I switch off the machine and tried to enable low resolution mode but to no avail. it only works in safe mode. when I uninstall the drivers in safe mode everything works perfectly In safe mode but I want want to use the onboard gpu cos my gtx 660 is no more. so I wish the gurus here help me fix this problem.
system specs
hp compaq la2306x monitor
I7 3770k
asus maximua v formula board
8 gb corsair vengeance ram
550 watts psu
500gb hdd
thanks
Black_Phoenix
Did you install the right drivers?
In the BIOS is the GPU Auto selected?
How much memory you had allocated to the GPU in the BIOS?
I had a little problem, different from yours with a PC that I fixed, that were basically almost the same, but with graphic corruption and a very slow system.
The solution was that in the BIOS the GPU from Intel had only 8MB of video memory allocated. I allocated 64MB for video memory to the integrated GPU and the slowness and graphic corruption had disappear (strange I know but it were the reason).
