02-24-2018
05:32 PM
- last edited on
03-05-2024
07:39 PM
by
ROGBot
07-09-2018 06:24 PM
07-25-2018 08:23 PM
08-03-2019 03:02 AM
04-16-2020 12:33 PM
10-01-2020 03:05 PM
Pipes69 wrote:
Hello All,
I'm having issues with my ethernet as well, When I built the system this week, It didn't post the first time So I had to update the bios, Which was easy enough with the bios flash option , Which worked perfectly.
My Crosshair vii x470 is plugged directly into router with my 3 other ASUS builds, They are getting over 600mbps, I'm only getting at the max 17mbps download speeds when downloading, I changed the cable with other computers and they were still getting over 600mbps with the same cable, I updated the windows ethernet drivers, moved it to different ports on router, Still only getting 17mbps download speeds, I have put together over a dozen Asus ROG motherboards the last 10 years and have never had this issue, I have always hard wired the either net and usually do not use wifi on my boards, I have tried just about everything I could think of trouble shooting this download speed issue, Everything else works great, I ordered a wifi adapter to see if I went wifi on not hard wire, I truly have only had 1 issue with my ASUS boards in the last 10 years so I just been sticking with ASUS on all my equipment, I do know this, When I did have that one problem, It was vary hard dealing with tech support, Hopefully someone out there has an Idea to share
Kind Regards
Windows 10 (latest Update)
Ryzen 3700x OC to 4.0
3600 Corsair DDR4 running at 3000
EVGA 1000
512gb M.2 in slot m.2-1
ASUS Strix Super advanced RTX 2080s
