Issue with Armoury Crate Installation
jrhlotke
I've got an ASUS ROG Strix X570-E Gaming MB. Its equipped with a Ryzen 5 3600X CPU, 32 GB RAM, MSI RT5500 XT Video Card, EVGA Nu Audio card. When going to install Armoury Crate whether from the setting in the BIOS when it boots up or downloading it from ASUS after the install screen display, the progress bar appears and after a few seconds the machine just reboots. No indication in Event Log (Running Windows 10) of anything wrong other then the reboot was unexpected. I've run memtest to check out the memory and it seems to be fine. Any ideas on what else to run or try? Bios is at 3001
jrhlotke
I forgot to add that the installation of the Windows 10 SDK and the driver app for the Audio card exhibit the same behavior. Plus Aura Sync isnt working without the Armoury Craate being installed.
