is it possible to use PG348Q PCBs for predator X34?
Caipirinha
Hi. is it possible to use the PG348Q monitor pieces (mainboard,control board,...) inside a troubled Acer predator X34 ?
for example iv heard some monitor boards have their ICs coded by the manufactures does anyone know anyhting about this?
_______i7 7820X
________RAMPAGE VI APEX
_________G.SKILL 4x8 @3733 16
__________MSI 1080ti LIGHTNING Z ||O'\\\\'O'////'O_|
___________Intel 750 PCIE SSD
____________Corsair AX1500i
_____________Corsair Obsidian 900D
_______________Corsair H150i Pro 360 AIO
ShaneP
for example iv heard some gimp freejobalert notepad++ monitor boards have their ICs coded by the manufactures does anyone know anyhting about this?
As far as i have learnt through past experiences and heard, I dont think its possible and you are right about the coded ICs. Still cant be sure until I try. Also update if you get it working.
Thanks and Regards,
Shane
