05-19-2020 10:00 PM - last edited 3 weeks ago by ROGBot
05-20-2020 09:49 PM
05-21-2020 12:40 AM
AS185 wrote:
I just realized that in our motherboards the information and details are rather short. This is, after all, a motherboard for experienced users.
Anyways, try enabling the XHCI hand-off feature in the USB Configuration menu inside the BIOS. Check if the U31G2_E1/U31G2_E2 option is also enabled. Save and boot into Windows. Attach the external hard drive, restart and boot into BIOS once again. Now you should have a feature in the USB Configuration menu displayed USB Mass Storage Driver Support. Enable it. Save and reboot. Try testing in Windows now, by unplugging the external device and plugging in for any strange sounds.
Hopefully, this works!
05-21-2020 01:21 AM
05-21-2020 02:31 AM
AS185 wrote:
Well, that's a bummer. I don't know then what could be the problem. The way I see it if the USB ports work, I guess it's alright however I guess the clicking sound could get annoying or you'll get used to it. Strange issue. The last thing to do is actually to test with a more powerful power supply unit. Your 1000 watts should be fine but who knows?
05-21-2020 07:06 AM
TheDeadPixel wrote:
Actually the clicking sound makes the HDD stop from reading or writing, can't even browse the files with file explorer, isn't practically not functional, even if it worked, I would worry It'd be damaged in long tun.
I don't have another PSU. I connected my HDD to a labtop, and while gaming, it functions fine.
From what I remember, the HDD worked fine when I had my CPU at stock clockspeed. So I guess, ASUS didn't really test this scenario in their QC department.
