GPU tweek more issues, why does this crap not work?
JustStarting
This has been going on for months now, literately months. Why is this program so messed up.
This is my first thread which i received no help on how to solve the issue.
https://rog.asus.com/forum/showthread.php?101432-SICK-of-GPU-tweak
Today i have just finished a clean install of windows 10. Only drivers installed are GPU, latest nvidia / GPU tweak v1626, NVME, chipset and lan Nothing else has been added and all my bios settings are at default without adding the XPM for memory.
On first opening GPU tweak... Boost clock of 22307
https://ibb.co/i3S2dz
When i clicked on gaming mode it switched to 09999 and is now stuck on this number no mater what preset i choose. There is also no way to change the number as you may notice the slider option is missing.
https://ibb.co/gXhPrK
Everything dated today 4/8/18
https://ibb.co/iazhdz
The reason for a clean install is my GPU was just sent back to ebuyer due to a faulty fan which has been going on for over a year and it got send back without being fixed and on first loading up GPU tweak i was meet with a boost clock of 00000 also GPU-Z was no longer showing any gpu usage in any test or game.
What is going on with this program / GPU why does it not work how its meant to? i have been having issues with GPU tweak now for ages and have tried many driver versions and all have had problems with wrong boost clocks and never showing the gpu usage. I aslo cannot use safe mode on the card as gpu tweak always crashes.
Please no comments about using MSI i should be able to use GPU tweak without theses problems. It was working fine at one point till i decided to update the driver and ever since then it has never worked right.
Rob_W_
Level 12
Gpu tweak is going through some updates with a beta testing prog, check out the sticky thread for it in ASUs software section, might be worth you trying it!
Edit, some good changes going on.*
JustStarting
Rob, I tried the beta out this afternoon and no good still wrong clocks. In fact when using easy mode and selecting ovc/gaming/silent is took the % to 222% forcing me to restart to recover. The pro mode the clocks were still wrong too only this time i could not change them as every time i moved the slider it would just reset. I got angry and uninstalled it. Will have to reinstall tomorrow and take some screenshots.
Still no GPU usage shows in gpu tweak / GPUZ but it does via task manager. This has been an issue for a long time. Clean install and still issues.
