05-24-2017
05:00 AM
- last edited on
03-05-2024
10:05 PM
by
ROGBot
05-24-2017 07:55 AM
05-24-2017 09:20 AM
Eleiyas@ASUS wrote:
definitely sounds like a graphics driver or card error. I'd recommend contacting ASUS support for this one, if you're sure everything is installed properly and up to date
05-24-2017 09:55 AM
05-24-2017 11:00 AM
davemon50 wrote:
My main laptop is the same as yours. I have had no issues like yours, no. Does it actually lock your computer, or is it just loss of video? If loss of video, is it just for that app? (i.e. if you hit the Windows key can you get into other things?)
I am wondering if you've checked your Asus software, like the Gaming Center for example, to see if you've got some overclock in there that isn't working well.
If you installed the Nvidia driver from the Asus website, try installing the latest one from the Nvidia site instead.
05-24-2017 02:24 PM
05-24-2017 09:24 PM
05-25-2017 01:02 AM
bender02 wrote:
I have no direct experience but I've seen some topics of the same error due to faulty video card.
05-25-2017 01:01 AM
davemon50 wrote:
What about the overclocking? Mine defaulted to an extreme profile on delivery.
One other thought, make sure you are plugged into a very stable, and if you can - independent, electrical circuit. Lots of power draw on the GPU when using the high end apps so you could be drawing too much power if the circuit is overloaded. If you're not plugged in when it happens, try plugging in.
05-25-2017 04:15 AM
wfn7744 wrote:
As far as I know my laptop isn't overclocked.
I've tried different houses with different independent circuits and the issue is still there.
Thanks a lot for your support Davemon50.
