I couldn't find a water cooling kit for my pny gtx 1080 so I looked at the founder edition evga 1080 ti water cooling kit and it needed a quick mod and worked on my pny 1080 just fine. you have to cut the heat sink down a little ( it hits the caps on the back side). once you do that the kit will fit perfectly and everthing else goes on like it should. temps dropped from 50c idle to 36c idle and 86c load to 56c load.
