59 REPLIES 59
Finally ::: We have Bios update ROG STRIX Z390-F :: 1005
https://www.asus.com/de/Motherboards/ROG-STRIX-Z390-F-GAMING/HelpDesk_Download/
And THERE ARE NEW DRIVERS
THX ASUS
MoKiChU
Level 40
I was not able to apply 0702 bios but to 'Not correct bios file' error but 0805 installed without any issue and so far stable as well.
0805 still very unstable, back to 0602 for now.
What exactly is unstable? I haven't noticed anything unstable about it
RAM Mostly, but with 0805 my CPU's overclock. RAM is also unstable with 0702/0802 as well. 0602 is right as rain. Long story short, I've never been able to run XMP, so I've had to manually tune RAM in order to get it to work.
With the 1. Release Bios you can see the VRM temperatur in the BIOS and in the AI Suite. With ALL other Bios Versions there is no VRM Temp. Why is this?
Same problem, RAM is very unstable on 0805. On 0602, everything runs fine with a i5-9600k at stock clocks and 2x F4-3200C16D-16GVRB at XMP DDR4-3200. But with 0805, I've gotten multiple blue screens over the course of a week, and Prime95 fails in under a minute, even with RAM running at stock DDR4-2133. It's quite ironic that DRAM stability is supposed to be better with 0805.
MoKiChU
Level 40
Thanks. Updated Z390-F from 0805 to 0903, no issues, same stability as before. Just to let everyone know.
