Deleted
MoKiChU
Level 40
370 REPLIES 370
Where can i find the "A2_B-DIE Bios" for Gene ?
1mluer
Level 11
Just installed the Maximus XI Apex 1005 bios from 0905 currently installed. It went in without a hitch.. everything seems to be fine after re-configuration. It even remembered my Raid Volume and didn't corrupt it.
InWin 909 Silver RGB build
i9-10900k
ROG Maximus XII Apex
ROG Matrix 2080 ti
Gskill Trident Royal 4400 16g
Everything overclocked and love it.
ROG Awesomeness !!!!
check on the event viewer for event 15 with these and the nvidia drivers droping
ACPI Event 15 warning
The embedded controller (EC) returned data when none was requested. The BIOS might be trying to access the EC without synchronizing with the operating system. This data will be ignored. No further action is necessary; however, you should check with your computer manufacturer for an upgraded BIOS.
Learn, Play Enjoy! We help and collaborate, NOT complain!
On my second XI Extreme, heres something you might want to take a look at;
Spontaneously frozen loadscreen and error code B4 Load VGA bios
(Both on first and second motherboard, different GPUs/Components, fresh installs asf)
Bios 0602 0802 0902 0905 1005
I did also feel on some random occasion on the code XI.
One thing that i do these clean install. On the bios, my code have something called AMI NVME SUPPORT (using a 960evo with drivers). i turn off that. Also i am still running fast startup
i will check if that still happening i know that was present when my os was a on a normal SSD
Getting a few of these too.. intermittently. I also have stuff like Aida64 which I think can generate these types of errors. I am highly suspectful of the installation of the nihimicAPI as well. It loaded both the 64 and 32 bit versions in memory. I am not sure what is using that API but I think it is hanging a bit.
i9-10900k
ROG Matrix 2080 ti
the big part of those errors are windows. We have to wait that the 1903 (May update) lands and see what it up. I will update to drivers only later, but I am trying that Asus make these official with making some nice words.
MrAgapiGC
Level 14
I get another NVME for my code xi.
Can anyone tell me. How to make raid on nvme 2280 (normal size) if i can not use both?
MoKiChU
Level 40
MoKiChU wrote:
Hi everyone,
New BIOS 1105 [20/06/2019] for ROG Maximus XI Extreme/Gene/Hero has just been released :
Thread updated.
oki doki let me check. these new bios
Maybe still pending on the server reload.
