Country problem
BaxterTheFly
Hello, i have made account a few days ago and i couldnt chose the country i reside in because the choice was just iggnored when i tried to finis the registration. I than chose the nearest possible solution and went with Slovenia instead of Serbia ( which does not exist as a choice but it is still as a Serbia and Montenegro that disbanded 8 years ago ). Could any of moderators please switch that for me, i would be really grateful. Also it would be nice if, for the sake of keeping up to date, split the Serbia and Montenegro to Serbia as a single country and Montenegro as single country 🙂
X-ROG
Level 15
Hi, Thanks for bringing this to our attention.
This is a vBulletin forum issue sorry - must be a standard country list. If you login to your ASUS member account - account.asus.com - using the same email and password you use for the forums you can update your location to Serbia alone there.
I will get our webteam to see if they can manually update vB.
X-ROG
Level 15
This has now been fixed.
