CoolerMaster MasterLiquid ML240R RGB Fan placement (NZXT S340Elite, Asus X Apex)
Gold333
Hi all,
I'm running into a dilemma.
My CoolerMaster MasterLiquid ML240R RGB manual is telling me to place my fans in front of the radiator like this:
But some reviews on the internet have them placed behind the radiator like so:
Which is correct?
Seeing as they are RGB and feature lights it doesn't make sense to place them behind the radiator.
Can someone help a noob, I haven't built a PC in 10 years and I'm making dumb mistakes.
The build is a:
Asus X Apex
8700K
G.Skill Trident Z 2x8gb 3200mhz 14's
WD Black 1TB NVMe Dimm.2
NZXT S340 Elite
ph0n1c5
I have tested both way's and to be honest I did not see any difference, so go for front and pull air in to case and exhaust out back and top if you can.79069
79070
