BIG problem. Please advice!!!
PinkJackal
I have a problem with my PC. I've turned it on this morning and I saw my HDD full, after a search I found that a hidden folder caled "recyclebin" have been created, I have delete it and than has appear again, I've search with malwarebytes full version an nothing was found. What do you guys think??? Look at the pictures!
46894
46895
4 REPLIES 4
MeanMachine
Hi PinkJackal and your Recycle Bin is there for you to use and is important, and not Malware
Your Recycle Bin is part of Windows and provides a means of deleting and recovering Files you may have deleted or wish to get rid of.
If your disk is full, you would want to uninstall some unused programs or files, to allow at least 10% of unused disk space, to enable your OS to be defragged if your OS is on a HDD.
Have the Recycle bin Icon on your desktop and clear it out every so often or it will do it itself if it becomes full.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
PinkJackal
Well yes I know, but the problem is that every time I delete the files that are in the hidden recycle bin, it will fill again until no disk space is available! My actual recycle bin is empty! It happens in C:\ and in D:\
MeanMachine
Hi PinkJackal, Sorry for the misuderstanding.
You may have indeed contracted the recyclebin trojan, (Redirects web browsing activity) it is nasty and can hide from Malware detectors.
Strange, if indeed Malwarebytes did not detect it, although if you failed to keep your data base updated, it can sneak through.
Maybe it is a root viral infection and Malwarebytes has a rootkit revealer. Try that. Also try Spybot Search and Destroy.
You can also try by using a restore point, earlier than the infection or failing that a registry fix is required.
I have never encountered it myself, but you can go into safe mode, hide all system files and edit the registry. This should not be done unless you have expertise in registry edit as you may render your OS inoperable, if wrong registry keys are deleted. There is information on the net for the registry edit.
This maybe worth reading if indeed you have the Trojan: http://www.bleepingcomputer.com/forums/t/289569/infected-by-recycler-recyclebin-virusworm/
My System Specs:
CPU:
[/HR]
PinkJackal
I think I've found it with SpyHunter!! Thx guys, if I didn't succeed I'll let you know! THX!
