avatar problem
Reaper-S117
hi i cant seem to add a avatar image, only have option to "Do Not Use An Avatar"
and also cant edit profile pic
35 REPLIES 35
X-ROG
Level 15
Hi Reaper,
All new members cannot set an avatar until a minimum of 5 posts and have been a member 5 days. At which time your account is automatically upgraded to verified member giving you access to all the forum functions 🙂
MarshallR@ASUS wrote:
Hi Reaper,
good to know thnx
Hi Reaper,
Thanks man!!! I have been trying to figure this out.... They should tell you on the page that you have to do that first...
Good Idea.... on the list I am sure.. update rules. check. yep there it is. right there...
n o w ..... that's a list.
Welcome NewROGr'z....
im actually surprised that ive never heard of ROG till a couple of weeks ago when i decided to get the rampage IV extreme, glad i have, now looking at the xonar when it comes out
hi, ive posted more then 5 time and have been a member for 5 days, but i still dont have access to full profile settings like avatar and profile pic
This is some good info to know. I'm glad I found this thread after racking my head for 30 mins trying to get my avatar to work.:p
Hi Reaper,
Thanks I was wondering the same question.
Retired
Not applicable
I can't put in my new avatar Daemon made, I have been a member for way longer than 5 days and this is my 6th post
